iam trying to connect fluent sesion opened in Linux cluster from my windows machine by using connect_fluent methode, iam successfully abel to connect it but when i tried to initiate file transfer service by using the below command
"docker run -p 50000:50000 -v `pwd`:/home/container/workdir -u `id -u`:`id -g` filetransfer-tool-server" mentioned in the pyfluent docs iam getting error like below..
[my@hpc docker]$ docker run -p 50000:50000 -v `pwd`:/home/container/workdir -u `id -u`:`id -g` filetransfer-tool-server
? registry.access.redhat.com/filetransfer-tool-server:latest
Trying to pull registry.access.redhat.com/filetransfer-tool-server:latest...
Error: initializing source docker://registry.access.redhat.com/filetransfer-tool-server:latest: reading manifest latest in registry.access.redhat.com/filetransfer-tool-server: name unknown: Repo not found
? registry.redhat.io/filetransfer-tool-server:latest
Trying to pull registry.redhat.io/filetransfer-tool-server:latest...
Error: initializing source docker://registry.redhat.io/filetransfer-tool-server:latest: unable to retrieve auth token: invalid username/password: unauthorized: Please login to the Red Hat Registry using your Customer Portal credentials. Further instructions can be found here: https://access.redhat.com/RegistryAuthentication
? docker.io/library/filetransfer-tool-server:latest
Trying to pull docker.io/library/filetransfer-tool-server:latest...
Error: initializing source docker://filetransfer-tool-server:latest: reading manifest latest in docker.io/library/filetransfer-tool-server: requested access to the resource is denied
