Bolt Pretension by Named Selection
Drago
Drago Member, Employee Posts: 17
Second Anniversary Ansys Employee First Comment Photogenic
edited July 2023 in Structures
After creating a Bolt Pretension with:
newBoltPretension = Model.Analyses[0].AddBoltPretension()
I am wondering how to change the scoping to a Named Selection and how to assign a value. Thank you
Best Answers
  • Drago
    edited July 2023 Answer ✓
    Assuming the NS is ‘Bolt 1‘, with the following it can be assigned to the selection:
    BoltObj = DataModel.GetObjectsByName(selection)[0]
    Pretension.Location = Obj
    Assuming that the force to be applied is 1000 N, it can be applied with:
    Pretension.SetDefineBy(1,BoltLoadDefineBy.Load)
    Pretension.Preload.Output.SetDiscreteValue(0,Quantity("1000[N]"))
    The solution was taken from KM #2056373
  • M
    M Member, Employee Posts: 256
    # Get Beam objects
    myObj = 'Connections'
    myBeamsIDs = []
    myLoads = [1,2,3,4]
    obj = ExtAPI.DataModel.GetObjectsByName(myObj)[0]
    for beam in obj.Children:
        if 'Beam' in beam.GetType().ToString():
            myBeamsIDs.append(beam.ObjectId)
    # Create Bolt Pretension for each Beam
    ctr = 0
    for beam in myBeamsIDs:
        boltPreTens = model.Analyses[0].AddBoltPretension()
        boltPreTens.InternalObject.GeometryDefineBy = 19  # secret sauce
        boltPreTens.InternalObject.BeamConnectionSelection = beam
        load = Quantity(myLoads[ctr],'N')
        #boltPreTens.Formulation = FormulationType.SmallRotation
        boltPreTens.Preload.Output.Field.Output.SetDiscreteValue(1,load)
        ctr +=1
  • Rohith Patchigolla
    edited November 2024 Answer ✓
    Alternate method to create Bolt Pretension with Beam Connection scoped to it. As using InternalObject might have some issues (eg: Linux)
    boltObj = DataModel.GetObjectsByType(DataModelObjectCategory.Beam)[0]
    analysisObj = DataModel.AnalysisList[0]
    boltObj.Activate()
    import context_menu
    context_menu.DoEditCopy(ExtAPI)
    analysisObj.Activate()
    context_menu.DoEditPaste(ExtAPI)
    However, if you are using PyMechanical (Embedded mode), the above solution, or the method suggested in the previous post unforunately doesn't seem to work
    Please use the below,
    boltPreTens.PropertyByName("GeometryDefineBy").InternalValue = 19
    Instead of,
