How can I create a bolt pretension probe through scripting?
Pernelle Marone-Hitz
Pernelle Marone-Hitz Member, Moderator, Employee Posts: 898
    analysis = ExtAPI.DataModel.Project.Model.Analyses[0] # reference analysis
    boltPretensionList =analysis.GetChildren(DataModelObjectCategory.BoltPretension,True) # get a list of all bolt pretension objects in the tree
    solution = ExtAPI.DataModel.Project.Model.Analyses[0].Solution # reference solution
    boltProbe=solution.AddBoltPretensionProbe() # add a bolt pretension probe
    boltProbe.Name="abc" # give specific name to result
    boltProbe.BoundaryConditionSelection=boltPretensionList[0] # select first object in the "boltPretensionList" list
    To retrieve the values and unit system, one can use:
    boltProbe.MaximumWorkingLoad.Value
    boltProbe.MaximumWorkingLoad.Unit
