I am trying to use SBR+ in HFSS to produce some data for radar scenario in total I need 1500 scenarios , but the simulation are halted after computing around 500 scenarios , even if I restart the simulation , it says like simulation starting from 500 th iteration , it will again stop after next 500 or so iteration , but that does-not end up producing 1000 .transient files in the results folder. (I am using a HPC cluster with slurm script for simulation , I have a normal HPC license (it is not pack or workbench lisence) ) , there is no space issue either. I am wondering is it because of license or something else. If you need .aedt file or the slurm script I can give that too.
