I am working on report automation and able to extract the figure currently working on extracting high stress and strain
You can use this sample script for the above case but this won't capture the section view-
import math import units stat = Model.Analyses[0] soln = stat.Solution tolerance=1000 equiv_stress = soln.AddEquivalentStress() soln.EvaluateAllResults() plot_data = equiv_stress.PlotData mesh_node_ids = [node.Id for node in stat.MeshData.Nodes] stress = {} for i, node_id in enumerate(plot_data['Node']): if node_id in mesh_node_ids: stress[node_id] = plot_data['Values'][i] max_value = equiv_stress.Maximum.Value max_nodes = [] for node_id,value in stress.items(): try: if abs(round(value, 2) - round(max_value, 2))<tolerance: max_nodes.append(node_id) except: continue for node_id in max_nodes: node_obj = stat.MeshData.Nodes[node_id] x = node_obj.X y = node_obj.Y z = node_obj.Z cam = Graphics.Camera zoom_level = Quantity(75, "mm") cam.SceneHeight = zoom_level cam.SceneWidth=zoom_level offset = 500 target_p = Point((x, y, z), "mm") eye_p = Vector3D(x + offset, y + offset, z + offset) up_v = Vector3D(0, 1, 0) cam.FocalPoint=target_p cam.ViewVector=eye_p cam.UpVector=up_v Graphics.Redraw() soln.AddImage()
@Mahesh_G said: I am working on report automation and able to extract the figure currently working on extracting high stress and strain !
