How can I extract participation factors of a modal analysis?
Pernelle Marone-Hitz
How can I extract participation factors or ratio of effective mass of a modal analysis through scripting?
    Participation factors and similar results are not exposed in GetResultsData.A workaround is to open and read the solver output file to access the information. The following code will extract the ratio of effective mass to total mass:
        # Read solve.out file and store it line by line
            FileDir=ExtAPI.DataModel.AnalysisList[0].WorkingDir
            TextFile='solve.out'
            SolveOutLines = [] #Declare an empty list named "lines"
            with open(os.path.join(FileDir, TextFile), "r") as in_file:
                for line in in_file: #For each line of text store in a string variable named "SolveOutLines", and
                    SolveOutLines.append(line)  #add that line to list of lines.
            # Create dictionnaries to store frequencies and participation factors (in fact will store ratio of effective mass to total mass)
            RatioX={}
            RatioY={}
            RatioZ={}
            # In SolveOutLines search for participation factors
            for line in range(len(SolveOutLines)):
                if SolveOutLines[line]=='          ***** PARTICIPATION FACTOR CALCULATION *****  X  DIRECTION\n' :
                    LineStart=line+3
                    LineEnd=LineStart+NumberOfModes
                    for i in range(LineStart,LineEnd):
                        temp_list=SolveOutLines[i].split(' ') # split text at ' '
                        temp_list2=[]
                        for j in range(len(temp_list)):
                            if temp_list[j] != '' :
                                temp_list2.append(temp_list[j])
                        RatioX[temp_list2[1]]=temp_list2[7]
                elif SolveOutLines[line]=='          ***** PARTICIPATION FACTOR CALCULATION *****  Y  DIRECTION\n' :
                    LineStart=line+3
                        temp_list2=[]
                        RatioY[temp_list2[1]]=temp_list2[7]
                elif SolveOutLines[line]=='          ***** PARTICIPATION FACTOR CALCULATION *****  Z  DIRECTION\n' :
                    LineStart=line+3
                        temp_list2=[]
                        RatioZ[temp_list2[1]]=temp_list2[7]
            # Deal with numbers that have ('\n') due to exponent coding
            CorrectX=RatioX.values()
            for i in range(len(CorrectX)):
                temp_str=CorrectX[i].split('\n')
                CorrectX[i]=temp_str[0]
            j=0
            for i in RatioX:
                RatioX[i]=CorrectX[j]
                j=j+1
            CorrectY=RatioY.values()
            for i in range(len(CorrectY)):
                temp_str=CorrectY[i].split('\n')
                CorrectY[i]=temp_str[0]
            j=0
            for i in RatioY:
                RatioY[i]=CorrectY[j]
                j=j+1
            CorrectZ=RatioZ.values()
            for i in range(len(CorrectZ)):
                temp_str=CorrectZ[i].split('\n')
                CorrectZ[i]=temp_str[0]
            j=0
            for i in RatioZ:
                RatioZ[i]=CorrectZ[j]
                j=j+1
    @Pernelle Marone-Hitz ,
    Is there any way to get the participation factors more directly other than parsing the text of the solve.out file? They are reported in the Solution Information object in the worksheet, so Mechanical must have the data stored somewhere internally, correct?
    @Mike.Thompson That's a very old post, initially from 2018 (?). At the time there was no better solution, I haven't checked more recent versions, but it would be great to have a better solution.
  • dafedin
    dafedin Member Posts: 21
    Hello @Pernelle Marone-Hitz
    Is there a solution for getting data from the Solution Worksheet like Component Names, component items Ids etc.?
    edited May 27
    A new DPF operator was recently added to read modal participation factors from the mode file:
    ansys.dpf.core.operators.result.spectrum_data.spectrum_data
  • Landon Mitchell Kanner
    edited August 2024
    The DPF operator is giving the follow error:
    OSError: exception: access violation reading 0x0000000000000000
    Here is the code:
    from ansys.dpf.core import animation
    my_data_sources = dpf.DataSources(examples.download_modal_frame())
    op = dpf.operators.result.spectrum_data(data_sources=my_data_sources)
    result_participation_factors = op.outputs.participation_factors()
    And here is the Traceback:
    File "", line 1, in
    File "C:\Users\lmkanner\AppData\Local\Programs\Python\Python310\lib\site-packages\ansys\dpf\core\outputs.py", line 75, in call
    return self.get_data()
    File "C:\Users\lmkanner\AppData\Local\Programs\Python\Python310\lib\site-packages\ansys\dpf\core\outputs.py", line 72, in get_data
    return self._operator.get_output(self._pin, type_output)
    File "C:\Users\lmkanner\AppData\Local\Programs\Python\Python310\lib\site-packages\ansys\dpf\core\dpf_operator.py", line 543, in get_output
    internal_obj = type_tuple[1](self, pin)
    File "C:\Users\lmkanner\AppData\Local\Programs\Python\Python310\lib\site-packages\ansys\dpf\gate\generated\operator_capi.py", line 420, in operator_getoutput_fields_container
    res = capi.dll.Operator_getoutput_FieldsContainer(op._internal_obj if op is not None else None, utils.to_int32(iOutput), ctypes.byref(utils.to_int32(errorSize)), ctypes.byref(sError))
    Any idea what is the cause?
  • Ayush Kumar
    Ayush Kumar Member, Moderator, Employee Posts: 508
    @Landon Mitchell Kanner can you try the following code? The participation factors are in the mode file, that must be added to the Data Sources.
    ds = dpf.DataSources()
    ds.add_file_path(r"\Path\to\file.mode")
    sd = dpf.Operator(r"spectrum_data")
    sd.inputs.data_sources.connect(ds)
    pf_fc = sd.outputs.participation_factors.get_data()
    print(pf_fc)
    print(pf_fc[1].data)
  • M
    M Member, Employee Posts: 256
    edited March 14
    If you are in Mechanical, you will need to generate a .mode file.
    You can do this by going into the analysis settings/Analysis Data Management/Future Analysis and setting it to something other than None (I used MSUP and that worked).
    import mech_dpf
    workdir = analysis.WorkingDir
    dataSource = dpf.DataSources(Model.Analyses[0].ResultFileName)
    path2mode = os.path.join(workdir,'file.mode')
    ds.AddFilePath(path2mode)
    op = dpf.operators.result.spectrum_data() # operator instantiation
    op.inputs.data_sources.Connect(ds)
    my_participation_factors = op.outputs.participation_factors.GetData()
    print(my_participation_factors)
  • M
    edited March 14
    @SimonFr
    And if you want to directly export all the particpation factor calculation data from the solve. out file to a csv saved to the user directory (building on Pernelle's solution above):
    import wbjn
    import re
    data = []
    UserFilesDirectory = wbjn.ExecuteCommand(ExtAPI, "returnValue(GetUserFilesDirectory())")
    dp=wbjn.ExecuteCommand(ExtAPI,"returnValue(Parameters.GetCurrentDesignPoint().DisplayText)")
    FileDir = ExtAPI.DataModel.AnalysisList[0].WorkingDir
    out_path = os.path.join(FileDir,'solve.out')
    result_file = 'PartFact_%s.csv'%dp.replace(' ','_')
    result_file_path = os.path.join(UserFilesDirectory,result_file)
    ctr = 0
    with open(out_path,'r') as f:
        dir_data={}
        out = f.readlines()
        for line in out:
            if 'NUMBER OF MODES TO EXTRACT' in line:
                n_modes = int(line.split()[-1])
            if 'PARTICIPATION FACTOR CALCULATION' in line:
                direction = out[ctr].split('DIRECTION')[0][-5:].strip()
                headers = out[ctr+2]
                headers = re.split(r'\s{2,}', headers)[1:]
                temp = out[ctr + 3:ctr + 3 + n_modes]
                temp1 = []
                for l in temp:
                    temp1.append([float(i) for i in l.split()])
                dir_data[direction] = temp1
            ctr+=1
    sort_dir = sorted(dir_data.keys())
    sort_dir = ['X','Y','Z','ROTX','ROTY','ROTZ']
    with open (result_file_path,'w') as f:
        for direction in sort_dir:
            f.write(direction + '\n')
            [f.write(i+',' ) for i in headers]
            for line in dir_data[direction]:
                [f.write(str(i)+',' ) for i in line]
                f.write('\n')
