How to create an Ansys UI Toolkit GUI box to get input from the user?
Note: Ansys UI Toolkit is not supported.
import clr clr.AddReference("Ans.Utilities") clr.AddReference('Ans.UI.Toolkit') clr.AddReference('Ans.UI.Toolkit.Base') import Ansys.UI.Toolkit import Ansys.UI.Toolkit.Base class Example1Window(Ansys.UI.Toolkit.Window): aLabel = None aButton = None aTextBox = None mainPanel = None def __init__(self): self.Location = Ansys.UI.Toolkit.Drawing.Point(100,100) self.Text = 'Example One' self.Size = Ansys.UI.Toolkit.Drawing.Size(200,100) self.StatusBar.Visible = False self.__BuildUI() #this will be defined later self.BeforeClose += Ansys.UI.Toolkit.WindowCloseEventDelegate(self.Window_Close) def __BuildUI(self): self.mainPanel = Ansys.UI.Toolkit.TableLayoutPanel() self.Add(self.mainPanel) self.mainPanel.Columns.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 100) self.mainPanel.Rows.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 33) self.mainPanel.Rows.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 34) self.mainPanel.Rows.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 33) self.aLabel = Ansys.UI.Toolkit.Label('This is a Label!') self.mainPanel.Controls.Add(self.aLabel, 0, 0) self.aTextBox = Ansys.UI.Toolkit.TextBox() self.aTextBox.Text = 'A Text Box' self.mainPanel.Controls.Add(self.aTextBox, 1, 0) self.aButton = Ansys.UI.Toolkit.Button('Here is a Button!') self.aButton.Click += Ansys.UI.Toolkit.EventDelegate(self.On_Click) self.mainPanel.Controls.Add(self.aButton, 2, 0) def On_Click(self, sender, args): resultString = 'You clicked the button!' + '\n' resultString += 'You typed \'' + self.aTextBox.Text + '\'.' Ansys.UI.Toolkit.MessageBox.Show(self, resultString, 'Example One', Ansys.UI.Toolkit.MessageBoxType.Info, Ansys.UI.Toolkit.MessageBoxButtons.OK) print self.aTextBox.Text def Window_Close(self, sender, args): Ansys.UI.Toolkit.Application.Quit() class ExampleOne: ex1 = None def __init__(self): self.ex1 = Example1Window() def Run(self): Ansys.UI.Toolkit.Application.Initialize() self.ex1.Show() Ansys.UI.Toolkit.Application.Run() example = ExampleOne() example.Run()
Hi Ayush! Thanks for a great example. So far I've been using System.Windows.Forms instead of Ansys.UI.Toolkit. You mention training and Toolkit documentation, but I can't find either. Could you share where to find it? I found a post that stated, there is no such documentation (https://discuss.ansys.com/discussion/2130/is-there-any-documentation-for-the-ansys-ui-toolkit).
Also, I tried to use ComboBox, but I cannot change its style to DropDown. I get various errors like: Traceback (most recent call last): AttributeError: attribute 'DropDownStyle' of 'namespace#' object is read-only
In regular Windows.Forms it works more or less like: self._comboBox = System.Windows.Forms.ComboBox() self._comboBox.DropDownStyle = ComboBoxStyle.DropDownList self._comboBox.Items.Add("a")
I am not 100% sure, but I don’t believe the UI Toolkit is officially supported or documented. That said, I find it quite useful. Windows forms is also quite useful in a similar way.
For an example of more advanced implementation of the UI toolkit you can refer to the bolt tools add on in mechanical. If you enable this, add on and open the script console, you can go to that extension scope, and get the directory for the add-on. In this location you will find numerous files that use this UI toolkit, but specifically WizardControlsV2.py will have lots of helpful tools for building UI that allows for geometry selection, tree, object, selection, drop down options, text, or numeric input, etc.…. For examples of using that module refer to almost any file that ends in GUI.
@Mateusz, sorry for the confusion. As I added in the note on the top of the code, "Ansys.UI.Toolkit" is not officially supported and nor is it documented. I removed the line that caused the confusion.
Please follow the hints provided by @Mike.Thompson for more examples on UI Toolkit but you can use Winforms as well for GUI functionalities.
Thanks @Mike.Thompson and @Ayush Kumar for such a quick response! I should start to use this forum more often
Think I'll stick to Winforms then. But I'll definitely check the Bolt Tool out, as I find it pretty interesting inside the Mechanical!
Hello scripting community,
I did some enhancements to the code @Ayush Kumar posted above.
user_input
ExampleOne
Example1Window
UserInputWindow
Window_Close()
__init__
On_Click
def My_Subsequent_Function(input_value): try: ''' This is where to add the code for your subsequent actions''' ExtAPI.Log.WriteMessage("My_Subsequent_Function has been called with input value " + str(input_value)) except Exception as e: ExtAPI.Log.WriteMessage(str(e)) def user_input(analysis): ExtAPI.Log.WriteMessage("User input function called") import clr clr.AddReference("Ans.Utilities") clr.AddReference('Ans.UI.Toolkit') clr.AddReference('Ans.UI.Toolkit.Base') import Ansys.UI.Toolkit import Ansys.UI.Toolkit.Base class UserInputWindow(Ansys.UI.Toolkit.Window): def __init__(self): self.Location = Ansys.UI.Toolkit.Drawing.Point(100,100) self.Text = 'User Input Window' self.Size = Ansys.UI.Toolkit.Drawing.Size(350,250) self.StatusBar.Visible = False self.__BuildUI() def __BuildUI(self): self.mainPanel = Ansys.UI.Toolkit.TableLayoutPanel() self.Add(self.mainPanel) self.mainPanel.Columns.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 100) self.mainPanel.Rows.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 33) self.mainPanel.Rows.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 34) self.mainPanel.Rows.Add(Ansys.UI.Toolkit.TableLayoutSizeType.Percent, 10) self.aLabel = Ansys.UI.Toolkit.Label('Add prompt for the user here.') self.mainPanel.Controls.Add(self.aLabel, 0, 0) self.aTextBox = Ansys.UI.Toolkit.TextBox() self.aTextBox.Text = '' self.mainPanel.Controls.Add(self.aTextBox, 1, 0) self.aButton = Ansys.UI.Toolkit.Button('OK') self.aButton.Click += Ansys.UI.Toolkit.EventDelegate(self.On_Click) self.mainPanel.Controls.Add(self.aButton, 2, 0) def On_Click(self, sender, args): ExtAPI.Log.WriteMessage("On Click Called") try: self.user_input_value = float(self.aTextBox.Text) ExtAPI.Log.WriteMessage("User input value is " + str(self.user_input_value)) except: warn_msg = "Warning: \nPlease type a numerical value!" Ansys.UI.Toolkit.MessageBox.Show(self, warn_msg,'Warning', Ansys.UI.Toolkit.MessageBoxType.Info, Ansys.UI.Toolkit.MessageBoxButtons.OK) if type(self.user_input_value) == float: Ansys.UI.Toolkit.Application.Quit() my_window = UserInputWindow() Ansys.UI.Toolkit.Application.Initialize() my_window.Show() Ansys.UI.Toolkit.Application.Run() My_Subsequent_Function(my_window.user_input_value)
Oh, I also added a trivial function My_Subsequent_Function, to test the workflow.
