How to add and orient local coordinate system in Mechanical?
Ayush Kumar
Member, Moderator, Employee Posts: 512
Best Answers
For 2020R2 and above:
# Add a coordinate system coordinate_systems = Model.CoordinateSystems csys = coordinate_systems.AddCoordinateSystem() # Define Primary Axis csys.PrimaryAxis = CoordinateSystemAxisType.PositiveZAxis # Orient the Primary Axis to a Vector csys.PrimaryAxisDirection = Vector3D(1, 0, 0) # Global X direction # Set the origin csys.SetOriginLocation(Quantity(0,"in"), Quantity(0,"in"), Quantity(0,"in")) # Refresh ExtAPI.DataModel.Tree.Refresh()
2 -
For 2020R1 and below I could only find a solution via Coordinate System Transformation:
# Add a coordinate system coordinate_systems = Model.CoordinateSystems csys = coordinate_systems.AddCoordinateSystem() # Set the origin csys.SetOriginLocation(Quantity(0,"in"), Quantity(0,"in"), Quantity(0,"in")) # Define Primary Axis csys.PrimaryAxis = CoordinateSystemAxisType.PositiveZAxis # Add a Rotational Transformation, each added Transformation gets an index starting from 1 csys.AddTransformation(TransformationType.Rotation, csys.PrimaryAxis) # Set a Transformation Value, say 45deg csys.SetTransformationValue(1, 45) # Add a Translational Transformation, index 2 csys.AddTransformation(TransformationType.Offset, csys.PrimaryAxis) # Set a Transformation Value, say 10mm csys.SetTransformationValue(2, 10) # Add a Rotational Transformation, index 3 csys.AddTransformation(TransformationType.Rotation, csys.PrimaryAxis) # Set a Rotational Value, say 10deg csys.SetTransformationValue(3, 10) “”” You can add multiple transformations …. “”” # Refresh ExtAPI.DataModel.Tree.Refresh()
2
hello, I want to create a coordinate system using the ACT script, code is
cs = Model.CoordinateSystems cs_obj = cs.AddCoordinateSystem() cs_obj.Name = "xz" cs_obj.OriginDefineBy = Ansys.Mechanical.DataModel.Enums.CoordinateSystemAlignmentType.Associative selection = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.GeometryEntities) selection.Ids = id_list cs_obj.OriginLocation = selection
but error is cs is None, How to solve it?0 -
@Erubus Can you please create a new discussion for this question and maybe share the screenshot of the error you get?
