User defined function in ACT console
Ayush Kumar
Ayush Kumar Member, Moderator, Employee Posts: 507
It is possible to write your own helper functions and they will be available in Mechanical ACT console.
  • Ayush Kumar
    Note: Just an internal trick, not supported.
    $AWP_ROOT202/Addins/ACT/libraries/Mechanical contains Python Modules which are loaded by default in Mechanical session. If you create a Python file for example helper.py in this folder, all functions within this file can be directly used in ACT Mechanical Console.
    Eg. Content of helper.py:
    def get_attributes(attribute_string, object):
        return filter(lambda x: (attribute_string.upper() in x.upper()), dir(object))
    Usage in Mechanical ACT console:
    import helper
    helper.get_attributes("Unit", analysis)
    Adding a few screenshots to illustrate:
    Module is then loaded in Mechanical:
    And function can be called:
  • Pierre Thieffry
    Ayush, don’t snippets help here? When you save a script as a snippet, it will appear as a choice in the console.
