Remove a value from surface thickness
Pernelle Marone-Hitz
Member, Moderator, Employee Posts: 894
Is there a way to remove a defined value from the thickness of surface bodies in Mechanical?
The following example can be used:
removeThickness = 0.0005 bodiesList = ExtAPI.DataModel.Project.Model.Geometry.GetChildren(DataModelObjectCategory.Body,True) geoData=ExtAPI.DataModel.Project.Model.Analyses[0].GeoData for body in bodiesList: geoBody=body.GetGeoBody() if geoBody.BodyType==GeoBodyTypeEnum.GeoBodySheet: if (geoBody.Thickness-removeThickness)>0: geoBody.Thickness=geoBody.Thickness-removeThickness
2
