Insert total deformation result in modal analysis scoped to a named selection and define maximum and
Pernelle Marone-Hitz
How can I insert a total deformation result in a modal analysis scoped to a named selection and define maximum and frequency values as parameters?
For example, you can use :
solu=ExtAPI.DataModel.Project.Model.Analyses[0].Solution # reference solution res=solu.AddTotalDeformation() # add total deformation result res.Location=ExtAPI.DataModel.GetObjectsByName("base")[0] # set location
In the line above, we use "GetObjectsByName" method that returns a list of all the entitites of the Mechanical tree. Here we are searching for all objects named "base" and then using the first object in this list (hopefully, a named selection named “base”)
As for specifying that the maximum and the frequency are parameters, one can use:
res.CreateParameter("Maximum") res.CreateParameter('ActualFrequency') ExtAPI.DataModel.Tree.Refresh()
Be careful, there is also a property called “Frequency” that is invisible in the details view, with an internal value of 0 Hz. Please refer to bug 385482 for further details.
