I've got linked static + (pre-stressed) modal analyses that have been solved. I'm trying to figure out how to retrieve parameters, produced by a post command from the static solution, using another post command in the modal system.
@fsalmon Since you are just reading results and not db file, the parameters may not pass through. You can write parameters in a temporary text file and then read it back in the downstream analysis.
This question should be ideally addressed in by Ansys Technical Support. Please raise a request.
