It comes up sometimes you may want to modify the mesh (move it, or add to it) and display some custom results on it. You can do this in Mechanical by a python result with DPF.
Below is an example of the code I used in a python results object to do something on the attached model.
You can see in the screenshot the mesh is moved and rotated from the body. I also have made new random elements in addition to the extracted mesh.
This is somewhat trivial in the example, but shows a powerful tool to generate any mesh, with any contours on it for visualization within this framework.
import mech_dpf
mech_dpf.setExtAPI(ExtAPI)
define_dpf_workflow(analysis)
def RotationMatrixFieldFromCS(CsName):
Use this to get a DPF rotation matrix from a CS.
CS = ExtAPI.DataModel.GetObjectsByName(CsName)[0]
CsMatrix = list(CS.Matrix)
TransformMatrix = [CsMatrix[i] for i in [0,3,6,1,4,7,2,5,8]]
rot_mat_f = dpf.FieldsFactory.CreateScalarField(1)
rot_mat_f.Data = TransformMatrix
return rot_mat_f
#get the node ids for what you want to use
node_ids = ExtAPI.DataModel.GetObjectsByName("MyNodes")[0].Ids
mesh_scoping = dpf.MeshScopingFactory.NodalScoping(node_ids)
#get the mesh from the .rst file
mesh_provider_op = dpf.operators.mesh.mesh_provider()
mesh_provider_op.inputs.data_sources.Connect(dataSource)
dpf_mesh= mesh_provider_op.outputs.mesh.GetData()
#create a skin/surface mesh on top of the nodes.
#This is a DPF mesh entity, not in the .rst file
#this is what will be plotted in mechancial
skin_op = dpf.operators.mesh.skin()
skin_op.inputs.mesh.Connect(dpf_mesh)
skin_op.inputs.mesh_scoping.Connect(mesh_scoping)
skin_mesh = skin_op.outputs.mesh.GetData()
#Add an arbitrary element to the mesh connected to nodes 1,2,3
skin_mesh.AddShellElement(skin_mesh.ElementCount+1, [1,2,3])
#Add new nodes and a new element to them
#This is just to show you can make any mesh you want and plot anything on it.
elem_size= Quantity(10,'mm')
elem_size_mesh_unit = Ansys.Core.Units.UnitsManager.ConvertUnit(elem_size.Value, elem_size.Unit, 'm')
skin_mesh.AddNode(skin_mesh.NodeCount+1, [0.,0.,0.])
skin_mesh.AddNode(skin_mesh.NodeCount+1, [0.,0.,elem_size_mesh_unit])
skin_mesh.AddNode(skin_mesh.NodeCount+1, [0.,elem_size_mesh_unit,elem_size_mesh_unit])
nd_indicies=range(skin_mesh.NodeCount-3, skin_mesh.NodeCount)
skin_mesh.AddShellElement(skin_mesh.ElementCount+1, nd_indicies)
#Get the element Ids just as something to plot on the elements
elem_id_field = dpf.Field()
elem_id_field.ScopingIds=skin_mesh.ElementIds
elem_id_field.Data=[float(Id) for Id in skin_mesh.ElementIds]
elem_id_field.Location=dpf.locations.elemental
#Rotate the mesh just to show you can move it around in post.
op = dpf.operators.geo.rotate() # operator instantiation
op.inputs.field.Connect(skin_mesh.CoordinatesField)
my_field_rotation_matrix=RotationMatrixFieldFromCS("ResultCS")
op.inputs.field_rotation_matrix.Connect(my_field_rotation_matrix)
rotated_coords_field = op.outputs.field.GetData()
skin_mesh.CoordinatesField.Data = rotated_coords_field.Data
#Make the workflow object as standard practice to plot.
dpf_workflow = dpf.Workflow()
#Plot the element ids
dpf_workflow.SetOutputContour(elem_id_field)
#plot this on the DPF skin mesh we created on the fly earlier.
dpf_workflow.SetOutputMesh(skin_mesh)
#Finish it up....
