I am trying to save a pathline file for ANSYS Fluent using pyfluent on linux (Ubuntu 24.04) by running the command
solver_session.execute_tui(f'solve/animate/pulse/write {specific_result_filename} {frames_output_dir}')
It works on Windows, but on Linux it gives the error <solve/animate/pulse/w Error: invalid command Error Object: "pulse">
When I run the exact TUI command on the Fluent GUI in Linux, it works as well. It's only with PyFluent (import ansys.fluent.core as pyfluent).
I also tried using both commands below, which led to other errors. Is this a limitation with Linux and PyFluent?
solver_session.tui.solve.animate.pulse.write(specific_result_filename, frames_output_dir)
solver_session.settings.results.graphics.pulse.write(object_name = specific_result_filename, file_name = frames_output_dir)
