In a Harmonic Response analysis:
A *DIM table is defined, and *TREAD with a *DO loop is used to read 100 CSV files, each containing force data at different frequencies.
After reading, the goal is to apply these table-based loads to 100 nodes individually.
In step 2), I intended to use a *DO loop to define and apply the 100 table loads. However, it seems that table loads cannot be parameterized — using a syntax like F, node, FX, %table_name%i%% is invalid.
Is there a way to apply multiple imported tables using a *DO loop, or any method to automate assigning these table loads node-by-node?
/PREP7
*DO, i, 1, 100
*DIM, LOAD%i%, TABLE, 200, 1
*TREAD,LOAD%i%,C:\Temp\load_%i%,csv,,2
F, i, FX, %LOAD%i%%
ALLSEL
*ENDDO
