Hello everyone,
I would like to have a clean, if possible, sweepable mesh transition from a pipe cross-section with different wall thicknesses and a chamfer, which is generated as a solid model. As an example, the lower part is meshed with a 40 mm mesh and the upper part with a 60 mm mesh. Both the lower and upper parts are generated using the sweep method and hexahedral elements. I would also like to use hexahedral elements for the transition. What would be a good solution here?!
Thanks for your help in advance.
