How to use matplotlib and numpy in Mechanical?
Ayush Kumar
Best Answers
  • Ayush Kumar
    By activating CPython console in Ansys Mechanical v2021R1 - How do I use CPython Console in Mechanical Scripting?
    Ideally you should be able to directly use matplotlib and numpy in Mechanical console as they are shipped with the default Ansys Workbench v2021R1. Check the site-packages in your installation folder:
    C:\Program Files\ANSYS Inc\v211\commonfiles\CPython\3_7\winx64\Release\python\Lib\site-packages
    But I got the following error when trying to do a 3D plot with matplotlib in Mechanical.
    Can't find a usable init.tcl in the following directories:
    This probably means that Tcl wasn't installed properly
    This means that tcl and tk libraries weren't installed properly. To get around this issue, one can download the exact CPython version shipped with Ansys WB 2021R1 (https://www.python.org/downloads/release/python-378/)
    And copy the tcl and tk folders from your local python installation folder: ...Python37_64\tcl
    enter image description here
    to C:\Program Files\ANSYS Inc\v211\commonfiles\CPython\3_7\winx64\Release\python\Lib
    and then restart Mechanical.
  • M
    M Member, Employee Posts: 256
    edited November 2022 Answer ✓
    Now even easier in 2022r2. If you set the beta options and enable Cpython options you will be able to set the Engine Type in a Python Code object.
    When you have a Cpython code object, then matplotlib will work without issue:
        plt.plot([1,2,3,4])
        plt.ylabel('some numbers')
        plt.show()
    This should by default generate an external matplotlib image:
  • Mahesh_G
    Mahesh_G Member Posts: 8
    edited March 2024
    In 22R2 & 23r2, I am not able to see the Engine with bita option as well
  • Rohith Patchigolla
    Rohith Patchigolla Member, Moderator, Employee Posts: 253
    Hello @Mahesh_G , one would need to go to WB --> Tools--> Options and activate the below Beta option and reopen Mechanical to have this Beta option in Mechanical in Python Code object.
  • Anon
    Anon Member Posts: 5
    And what do you do when this option is not available? (2023 R2)
    Hello @Anon , the picture indicates that the general beta options box is not checked.
    Could you check this box here , click okay and try again to set cpython capability?
  • Anon
    Yes thank you that did it.
