I have a customer trying to run a PyDPF script on a harmonic analysis model with 4 million nodes and 150 frequency values yielding an rst file 260GB in size. The script is able to extract stresses and accelerations as expected, but when trying to extract element nodal forces, it throws an error: ENF:81<-mapdl::rst::ENF:86<-memory allocation failed, failed to read element nodal forces from rst file. I suggested a workaround of reducing the mesh scoping but that did not help. On the other hand, extracting results for only 10 frequency values at a time seemed to work, though it takes around 10 minutes per named selection. I suspect this may reveal an issue with the element_nodal_forces operator. Customer is using Ansys 2024 R2 and DPF-Core version 13.8 on a computer with 512 GB of RAM.
Thank you for any insights you can provide.
Thanks,
Alex
