1.Assign a Remote Point and link the data of the corresponding edge to Measure_Point through a command.|
Apply a moment using a tabular input, divided into a total of 10 steps.
In Solution → Command (APDL), when applying the moment in 10 steps, write code to extract the rotation angle at each step.
Problem: In this state, the results cannot be viewed in the Result section.
I think there’s an issue in the code—how should I modify it?
