Good morning,
I am trying to write a script in Ansys Mechanical to modify a mesh that has been imported from a previous analysis.
Currently, the mesh is in "Read-Only" mode because the model is linked. While I can change this manually by clicking the Mesh object in the project tree and setting "Read-Only" to "No," I am unsure of the correct command to perform this action within a script.
Could you please provide the syntax or command needed to change the mesh from read-only to editable via scripting?
Thank you for your help.
