How to assign units to a custom result in the python file of an ACT extension?
Pernelle Marone-Hitz
In Mechanical, this can be done by modifying the value of "result.Unit", where "result" is one of the arguments of the function called. Below is an example :
def OnValidateResultType(result,property): if result.Properties["Result Type"].Value == "Length Result": result.Unit = "Length" elif result.Properties["Result Type"].Value == "Force Result": result.Unit = "Force" elif result.Properties["Result Type"].Value == "Moment Result": result.Unit = "Moment" elif result.Properties["Result Type"].Value == "Unitless Result": result.Unit = "Dimensionless"
4
