How can I get Rotational velocity boundary condition from the RST?
Using the*XPL command from PyMAPDL we can get the omegacgvalues (position 20, 21 and 22 in the record) as shown in the Results Description File.
*XPL
omegacg
Ansys Help Link
from ansys.mapdl.core import launch_mapdl mapdl = launch_mapdl() rst = r"D:\…\file.rst" mapdl.post1() mapdl.file(rst) xpl = mapdl.xpl xpl.open(rst) xpl.step('DSI') xpl.step("SET1") step_data = xpl.read("DPHEAD") omega_x = step_data[19] omega_y = step_data[20] omega_z = step_data[21] print(omega_x, omega_y, omega_z) xpl.close() mapdl.exit()
@Ayush Kumar Hi…
Is it possible to get all the Boundary Conditions from .rst using PyDPF.?
Thanks for posting this Ayush. This has always been a struggle. I wanted to point out a few things for clarification:
Since this uses the *XPL command, this can be done directly in MAPDL as well. I have attached a macro that does that.
@Naveen Kumar Begari no, you can't. The above code is using PyMAPDL.
@Jim Kosloski thanks for the hint - set, last is indeed isn't necessary, corrected.
