How can I get a user button to create a Python results with its script and properties?
Pierre Thieffry
A power user has created a Python result and would like to share it with other people. How can he do this?
  • Pierre Thieffry
    Well, here's one potential solution, as there is no "export button" or "generate user button" option.
    First run this script that will store the Python results script and property provider:
    pr=ExtAPI.DataModel.GetObjectsByName('Python Result')[0]
    script=pr.Text
    provider_text=pr.PropertyProviderText
    f=open(r'wherever\result_script.txt','w')
    f.write(script)
    f.write('\n***** delimiter\n') # use whatever delimiter
    f.write(provider_text)
    f.close()
    Then use this script to create the user button:
    current_object=ExtAPI.DataModel.Tree.FirstActiveObject
    if current_object.GetType()==Ansys.ACT.Automation.Mechanical.Solution: # user has selected a 'solution' under which the python result will be inserted
        new_presult=current_object.AddPythonResult()
        f=open(r'wherever\result_script.txt','r') # script content stored somewhere
        script=''
        provider_text=''
        line=f.readline()
        # read script text
        while line.find('***** delimiter')==-1: # same delimiter as above
            script+=line
            line=f.readline()
        line=f.readline()
        # read provider text
        while line:
            provider_text+=line
            line=f.readline()
        f.close()
        new_presult.PropertyProviderText=provider_text
        new_presult.Text=script
        new_presult.Connect()
        new_presult.ReloadProperties()
