How to access Tabular data using ACT?
Chemsdine CHEMAI
Chemsdine CHEMAI Member, Employee Posts: 201
100 Likes 100 Comments Second Anniversary Ansys Employee
edited December 2023 in Structures
Best Answers
  • Chemsdine CHEMAI
    It's possible using the following unsupported code :
    paneTabular=ExtAPI.UserInterface.GetPane(MechanicalPanelEnum.TabularData)
    control = paneTabular.ControlUnknown
    for col in range(1,control.ColumnsCount+1):
        for row in range(1,control.RowsCount+1):
            cellText= control.cell(row ,col ).Text
            if cellText!=None:
                print cellText
  • M
    M Member, Employee Posts: 256
    I enhanced your solution to write the table to a csv:
    import csv
    directory = 'D:/'
    for analysis in Model.Analyses:
        for solution in analysis.Solution.Children:
            if solution.Name != 'Solution Information':
                solution.Activate()
                num_columns = control.ColumnsCount+1
                num_rows = control.RowsCount+1
                result = []
                for row in range(1,num_rows):
                    r = []
                    for col in range(1,num_columns):
                        r.append(control.cell(row ,col ).Text)
                    result.append(r)
                save_name = os.path.join(directory, analysis.Name + ' '+ solution.Name+'.csv')
                with open(save_name, 'w') as f:
                    writer = csv.writer(f)
                    writer.writerows(result)
    This will write all tabular solution data to a csv. Please tell me there is a better way.
    It seems there is now (2021R2) a better way to access Tabular Data:
    TOTAL_DEFORMATION_1 = SOLUTION.AddTotalDeformation()
    FREQ1 = TOTAL_DEFORMATION_1.TabularData["Frequency"][0]
    See https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v212/en/act_script/act_script_demo_modal_acoustic.html for further reference.
  • M
    Here is a way to fill in a tabular data from an imported csv. The example here is a heat flow import (so the quantity units are sec and W).
    At the end, the time for the analysis settings is set.
    Thanks to Chems.
    import csv
    myData = r"D:\my\path\heatFlow.csv"
    rows = []
    with open(myData, 'r') as file:
        csvreader = csv.reader(file)
        header = next(csvreader)
        for row in csvreader:
            rows.append(row)
    timeSteps = len(rows)
    myTimes = [Quantity(float(i[0]), "sec") for i in rows] # create quantity lists for Discrete input
    myFlow = [Quantity(float(i[1]), "W") for i in rows]
    myHeatFlow = analysis.AddHeatFlow()
    myMag = myHeatFlow.Magnitude
    myMag.Inputs[0].DiscreteValues = myTimes
    myMag.Output.DiscreteValues = myFlow
    ## You might want to check this, it seems to work and avoid the duplication of the steps but might add 1 extra (+1) !!
    analysis.AnalysisSettings.NumberOfSteps = timeSteps
    with Transaction(suspendClicks=True):
        for t0 in range(timeSteps):
            analysis.AnalysisSettings.CurrentStepNumber= t0+1
            analysis.AnalysisSettings.StepEndTime = myTimes[t0+1]
  • M
    Annoying fact, fails w/ CPython
    Mike.Thompson Member, Employee Posts: 400
    This seems like it is not a general purpose solution for all tabular data (as of 2022.2) We can get it for Frequency, but not many other data types are supported, and it seems to return an error when trying to access TabularData for other types of columns.
  • Ben Klinkhammer
    Ben Klinkhammer Member, Employee Posts: 5
    Hi @Pernelle Marone-Hitz and @Mike.Thompson
    This seems to work for me for proper Tabular Data in Mechanical, but I can't seem to get it to work for tabular data coming from motion, etc where non-standard tables are used.
    For example, I want to extract some shaft sections out to a csv file, but I can't figure out how to access that tabular data (see pic below)
    Any help would be appreciated!
    Thanks,
    Ben
    There is a template available in the ACT templates on the customer portal. There is one specific for an example of this kind of tabular data for both the xml setup and the python usage.
    For the specifics of tabular data in Motion, @Gabriel Messager might have an example.
