Python Result example: Plot Young Modulus on elements
Pernelle Marone-Hitz
Using DPF inside a Python Result in Mechanical, how can I plot the material properties on each element of the model?
    edited September 2023
    Here's an example using the Young Modulus. It the adapation to Mechanical of an example provided in the PyDPF documentation: https://dpf.docs.pyansys.com/version/0.8/examples/00-basic/12-get_material_properties.html#sphx-glr-download-examples-00-basic-12-get-material-properties-py
    Model is made of two cubes in contact, with two different materials defined:
    Insert a Python Result object:
    Copy-paste and adapt the following code:
        define_dpf_workflow(analysis)
        import mech_dpf
        mech_dpf.setExtAPI(ExtAPI)
        # Define datasource and get mesh
        dataSources = dpf.DataSources()
        dataSources.SetResultFilePath(analysis.ResultFileName)
        model = dpf.Model(dataSources)
        mesh = model.Mesh
        # Get material properties and especially the Young Modulus values
        mats = mesh.GetPropertyField("mat")
        mat_prop = model.CreateOperator("mapdl_material_properties")
        mat_prop.inputs.materials.Connect(mats)
        mat_prop.inputs.properties_name.Connect("EX")
        mat_prop.inputs.data_sources.Connect(dataSources)
        mat_field = mat_prop.outputs.properties_value.GetData()[0]
        # Create a new field (elem number, Young Modulus on element)
        new_field = dpf.FieldsFactory.CreateScalarField(mesh.ElementCount)
        new_field.MeshedRegionSupport = mesh
        new_field.ScopingIds = mesh.ElementIds
        new_field.Location = 'Elemental'
        matids = [mats.GetEntityDataById(elem_id) for elem_id in mesh.ElementIds]
        young_modulus = [mat_field.GetEntityDataById(matid[0])[0] for matid in matids]
        new_field.Data = young_modulus
        # Forward field for plotting
        forward = dpf.operators.utility.forward_field()
        forward.inputs.field.Connect(new_field)
        dpf_workflow = dpf.Workflow()
        dpf_workflow.Add(forward)
        dpf_workflow.SetOutputContour(forward)
    Connect the result and evaluate it:
    The returned plot is:
  • Rohith Patchigolla
    Just for reference, here are the strings for different material properties to be input in place of "EX" in the above example.
    Young's modulus (keys: EX, EY, EZ),
    Poisson's ratio (keys: NUXY, NUYZ, NUXZ),
    Shear Modulus (keys: GXY, GYZ, GXZ),
    Coefficient of Thermal Expansion (keys: ALPX, ALPY, ALPZ),
    Volumic Mass (key: DENS),
    second Lame's coefficient (key: MU),
    Damping coefficient (key: DAMP),
    thermal Conductivity (keys: KXX, KYY, KZZ),
    Resistivity (keys: RSVX, RSVY, RSVZ),
    Specific heat in constant volume (key: C),
    Film coefficient (key: HF),
    Viscosity (key: VISC),
    Emissivity (key: EMIS).
