I have an analysis as follows: The model uses a cyclic region: I'd like to combine the results from the static and the harmonic analyses, but Mechanical's Solution Combination tool does not work in that case. Is there a solution through scripting?
DPF inside a Python result can be used to do that. Please note that the code below is just shared as a coding example, without any consideration of the physics behind the calculation (it could very well not make sense!). A Python Result is inserted in the Solution of the Harmonic Analysis. The code will:
def define_dpf_workflow(analysis): import mech_dpf import Ans.DataProcessing as dpf mech_dpf.setExtAPI(ExtAPI) # Extract data for harmonic response # With this method the dynamic expansion is done "on demand" in DPF data_source = dpf.DataSources(r'' + analysis.WorkingDir + 'file.rfrq') data_source_up = dpf.DataSources( r'' + analysis.WorkingDir + 'file.mode') data_source_up.AddFilePath(analysis.InitialConditions[0].ModalICEnvironment.ResultFileName) data_source.AppendUpStreamDataSources(data_source_up) u_harmo = dpf.operators.result.displacement() time_scop = dpf.Scoping() time_scop.Ids = [200] u_harmo.inputs.data_sources.Connect(data_source) u_harmo.inputs.time_scoping.Connect(time_scop) u_harmo.Connect(14, 2) # read cyclic and perform cyclic expansion op = dpf.operators.mesh.from_field() op.inputs.field.Connect(u_harmo.outputs.fields_container.GetData()[0]) my_mesh = op.outputs.mesh.GetData() amplitude = dpf.operators.math.amplitude_fc() amplitude.inputs.fields_container.Connect(u_harmo) # Extract total deformation for static analysis static_analysis = ExtAPI.DataModel.AnalysisByName('Static Structural') data_source_2 = dpf.DataSources(static_analysis.ResultFileName) u_static = dpf.operators.result.displacement() time_scop_2 = dpf.Scoping() time_scop_2.Ids = [1] u_static.inputs.data_sources.Connect(data_source_2) u_static.inputs.time_scoping.Connect(time_scop_2) u_static.Connect(14, 2) # read cyclic and perform cyclic expansion # Add both fields add_fc = dpf.operators.math.add_fc() add_fc.inputs.fields_container1.Connect(amplitude.outputs.fields_container.GetData()) add_fc.inputs.fields_container2.Connect(u_static.outputs.fields_container) # Take norm nrm = dpf.operators.math.norm_fc() nrm.Connect(add_fc) # Plot output = dpf.operators.utility.forward() output.inputs.any.Connect(nrm) dpf_workflow = dpf.Workflow() dpf_workflow.Add(nrm) dpf_workflow.SetOutputContour(nrm) dpf_workflow.SetOutputMesh(my_mesh) dpf_workflow.Record('wf_id', False) this.WorkflowId = dpf_workflow.GetRecordedId()
@Pernelle Marone-Hitz , I have a request for an example that is similar in nature to this. It is for fatigue calculations
The final output is a utilization of the fatigue allowable by comparing the modal, scaled, alternating stress to the allowable as determined by the mean stress and corresponding temperature-dependent S-N curve data.
