Is there an example of fatigue calculation with DPF?
The following example has no physical meaning and is just an illustration of DPF capabilies. It uses the dummy custom stress computed in this example, and reads the S-N curve of the material of the first body in the tree (adapt to your use case!).
Note - a value of -1 or -2 in the result plot will indicate that the interpolation of the number of cycles to failure could not be performed (usually due to lack of material data to interpolate).
Complete code:
def LinearInterpolation(x,x1,y1,x2,y2): # Simple linear interpolation # Returns -1 if x is outside of [x1,x2] if x<x1 or x>x2: return -1 # out of range if y1==y2: return y1 else: a=(y2-y1)/(x2-x1) b=y1-a*x1 return a*x+b def GetLocalCyclesToFailure(sn_curve, local_stress_si): cycles_list = sn_curve["Cycles"][1:] alternating_stress_list = sn_curve["Alternating Stress"][1:] index = 0 # Find closest cycle number in stress_data for i in range(len(cycles_list)): alt_stress = alternating_stress_list[i] if alt_stress < local_stress_si: index=i break # Get (cycles, alternating stress) points between which to interpolate if index!= len(cycles_list): y1=cycles_list[index] y2=cycles_list[index-1] x1=alternating_stress_list[index] x2=alternating_stress_list[index-1] else: return -2 # value is out of bounds return LinearInterpolation(local_stress_si,x1,y1,x2,y2) # return number of cycles def GetFieldCyclesToFailure(stress_op, sn_curve, analysis): import mech_dpf import Ans.DataProcessing as dpf node_ids = stress_op.outputs.getfields_container()[0].ScopingIds limit_field = dpf.FieldsFactory.CreateScalarField(1,'Nodal') stress_data = stress_op.outputs.getfields_container()[0] for nid in node_ids: local_stress =stress_data.GetEntityDataById(nid)[0] # Convert local stress to SI units local_stress_quantity = Quantity(str(local_stress) + '[' + analysis.CurrentConsistentUnitFromQuantityName("Stress") + ']') local_stress_si = local_stress_quantity.ConvertToUnitSystem("SI", "Stress").Value limit_field.Add(nid,[float(GetLocalCyclesToFailure(sn_curve, local_stress_si))]) return limit_field def define_dpf_workflow(analysis): import mech_dpf import Ans.DataProcessing as dpf mech_dpf.setExtAPI(ExtAPI) data_source = dpf.DataSources(analysis.ResultFileName) model = dpf.Model(data_source) mesh = model.Mesh # Get SN curves for material defined on first body in the Mechanical tree import materials first_body = Model.GetChildren(DataModelObjectCategory.Body, True)[0] material = ExtAPI.DataModel.GetObjectsByName(first_body.Material)[0] mat_enginerring_data = material.GetEngineeringDataMaterial() sn_curve = materials.GetMaterialPropertyByName(mat_enginerring_data,"S-N Curve") # Time sets timePointsOp =dpf.operators.metadata.time_freq_provider() timePointsOp.inputs.data_sources.Connect(data_source) timepoints = dpf.operators.metadata.time_freq_support_get_attribute(time_freq_support=timePointsOp,property_name="time_freqs",) # S1 prin1 = dpf.operators.result.stress_principal_1() prin1.inputs.data_sources.Connect(data_source) prin1.inputs.time_scoping.Connect(timepoints) # S3 prin3 = dpf.operators.result.stress_principal_3() prin3.inputs.data_sources.Connect(data_source) prin3.inputs.time_scoping.Connect(timepoints) # S1-S3 minus_fc = dpf.operators.math.minus_fc() minus_fc.inputs.field_or_fields_container_A.Connect(prin1.outputs.fields_container) minus_fc.inputs.field_or_fields_container_B.Connect(prin3.outputs.fields_container) # Scale factor scale = dpf.operators.math.scale_fc() scale.inputs.fields_container.Connect(minus_fc) scale.inputs.ponderation.Connect(sqrt(2)/2) # Get alternate stress min_max = dpf.operators.min_max.min_max_over_time_by_entity() min_max.inputs.fields_container.Connect(scale) min_field_by_time = min_max.outputs.getmin() max_field_by_time = min_max.outputs.getmax() alternate_stress = dpf.operators.math.minus_fc() alternate_stress.inputs.field_or_fields_container_A.Connect(min_max.outputs.getmax()) alternate_stress.inputs.field_or_fields_container_B.Connect(min_max.outputs.getmin()) # Get cycles to failure new_field = GetFieldCyclesToFailure(alternate_stress, sn_curve, analysis) output = dpf.operators.utility.forward() output.inputs.any.Connect(new_field) # Plot dpf_workflow = dpf.Workflow() dpf_workflow.Add(output) dpf_workflow.SetOutputContour(output) dpf_workflow.Record('wf_id', False) this.WorkflowId = dpf_workflow.GetRecordedId()
