How to automate the PSD load data improved fit?
Pernelle Marone-Hitz
Member, Moderator, Employee Posts: 894
Last time I checked, there was no supported API to do this. There is a workaround that uses unsupported commands - no guarantee that it will work, and use at your own risk.
# Activate "improved fit" PSGAcceleration=str(BaseExcitation.Name) cmd1=""" ds=DS; wb=WB; var oScript = DS.Script; var ListView=DS.Script.lv; var sm = DS.SelectionManager; var model = DS.Tree.FirstActiveModel; var myenvironments = model.Environments; var myEnv = myenvironments.Item(2); DSSelectTreeItem(""" cmd3="""); var Load = ds.Tree.FirstActiveObject; ListView.SelectItem("Load Data"); DS.Script.doImprovedPSDLoadFit(); // Find and Select a Branch by the "name" in the Tree // node = "name" function DSSelectTreeItem( node ) { if ( typeof(node) == "string" ) { var index = DSfindTreeNode( node ); // Start from top of tree if first search fails. if ( index == 0 ) { oScript.tv.SelectedItem = oScript.tv.Nodes(1); index = DSfindTreeNode( node ); } if ( index != 0 ) { oScript.tv.SelectedItem = oScript.tv.Nodes(index); } } } function DSfindTreeNode( name ) { var nameLower = name.toLowerCase(); var oNode = oScript.tv.SelectedItem; var textLower = oNode.Text.toLowerCase(); while( oNode != null && nameLower != textLower ) { oNode = oScript.GetNextItem( oNode ); if( oNode ) textLower = oNode.Text.toLowerCase(); } var index = 0; if( oNode != null ) { var nNodes = oScript.tv.Nodes.Count; for ( index = 1; index <= nNodes; index++ ) { if ( oScript.tv.Nodes(index) == oNode ) break; } if ( index > nNodes ) index = 0; } return index; } """ cmd=cmd1+"\""+PSGAcceleration+"\""+cmd3 ExtAPI.Application.ScriptByName('jscript').ExecuteCommand(cmd)
Hi @Pernelle Marone-Hitz,
I have the following script that might be useful to fit all the PSDs.def doImprovedFit(): cmd = ''' DS.Script.lv.SelectItem("Load Data"); DS.Script.doImprovedPSDLoadFit(); ''' ExtAPI.Application.ScriptByName('jscript').ExecuteCommand(cmd) type= DataModelObjectCategory.PSDLoad PSDs = DataModel.GetObjectsByType(type) nPSD = PSDs.Count for i in range(nPSD): PSDs[i].Activate() doImprovedFit()
I've the following script which might be useful to improve fit all the PSDs.
1
