Generate documentation for DPF
Pernelle Marone-Hitz
In 2020R2, from Mechanical, the documentation can be generated with the following lines of code:
import mech_dpf mech_dpf.setExtAPI(ExtAPI) import Ans.DataProcessing as dpf mech_dpf.help()
A string is returned in the console to show the folder in which the documentation is saved. It is saved in a .html file that can then be opened in any web browser.
3
is there anywhere a real docu for DPF available ?
Hi @klaus_2023 , you can use the PyDPF doc: https://dpf.docs.pyansys.com/version/stable/
But please keep in mind that PyDPF is CPython and Mechanical DPF is Iron Python, so names of methods can change slightly and examples will have to be adapted.
