Add beams inside mechanical at fastener holes automatically
Erik Kostson
Say we have multiple fastener holes (defined say as named selections), how can we then add automatically beams inside mechanical?
  • Erik Kostson
    edited March 2024 Answer ✓
    Below is the code for the automatic beam creation inside mechanical:
    It needs to have a cross section folder, and named selections created - each named selection is of the 2 edges that are to be connected by the beam. Beam will be connected to these 2 edges via 2 fixed joints (MPC rigid). Finally a Bolt-Pretension is added to the new beam.
    analysis=model.Analyses[0]
    ns=model.NamedSelections.Children
    construction_geometry = model.AddConstructionGeometry() # add folder
     # add line object
    for n in ns: # get named sel. hole edge pair needs to be there (so 2 edges)
        nId=n.Location.Ids
        a = construction_geometry.AddConstructionLine()
        pointlist=[]
        for edge in nId:
            e = ExtAPI.DataModel.GeoData.GeoEntityById(edge)
            if str(e.CurveType) =="GeoCurveCircle":
                ce=e.Centroid # get centre of hole
                #print(ce)
                pointlist.append((ce[0],ce[1],ce[2])) # beam points at the centre
                points=a.CreatePoints(pointlist)
        for i in range(0,len(points)-1):
            edge_collection_5 = a.CreateStraightLines([points[i],points[i+1]], [(0,1)]) # create the points and add beam
        beam=a.AddToGeometry() # create beam
        geobeam=beam.Bodies[0] #
        treebody=ExtAPI.DataModel.Project.Model.Geometry.GetBody(geobeam) # get tree body beam
        cross_sec=ExtAPI.DataModel.GetObjectsByType(DataModelObjectCategory.CrossSections)[0].AddCircularCrossSection()
        cross_sec.Radius = Quantity(float(e.Radius), "m")
        treebody.CrossSectionSelection=cross_sec
        connections = Model.Connections
        connectiongroup = connections.AddConnectionGroup()
        j=0
        for edge in nId: # create mpc rigid connections
            joint = connectiongroup.AddJoint()
            selection.Ids=[geobeam.Vertices[j].Id]
            joint.MobileLocation = selection
            selection.Ids=[edge]
            joint.ReferenceLocation = selection
            j=j+1
        bopr=analysis.AddBoltPretension()
        bopr.SetDefineBy(1,BoltLoadDefineBy.Load)
        load = Quantity(1000,'N')
        bopr.Preload.Output.Field.Output.SetDiscreteValue(0,load)
        selection.Ids=[geobeam.Edges[0].Id]
        bopr.Location=selection
