as you can see in the attached file i created an arch with Spaceclaim with each stone separate. The thickness changes from the beginning to the top. As next step I wanted to get the outer and inner surface of the arch (on top and bottom, not from the side as displayed on the screenshot). When I copy an edge of the arch, which I want to pull to create an area, the new copied edge is slightly different than the original edge and there is a very little but existing gap. Am I doing anything wrong or is this just normal?
Any help is appreciated. Thanks in advance.
~ Erik
