PyMAPDL:Plotting Nodal Temperatures in a Thermal (Fourier Heat Conduction) Problem
Sherlock007
Member Posts: 4
After mapdl.solu() I am attempting to plot the solution nodal temperatures:
I found two ways of doing that:
1)result = mapdl.result result.plot_nodal_temperature(0)
2) mapdl.post1() mapdl.set(1,1) mapdl.post_processing.plot_nodal_temperature()
Method 1 seems to work -> It matches with MAPDL solutions and satisfies the temperature BC's applied
Method 2: does not seems to work at all.
What is the issue? Could you please help?
My guess is you have more than 1 load/sub step and need to change
mapdl.set(1,1)
tomapdl.set('last')
