How can we read into arrays the x y z node locations and x y z displacements at these nodes?
There are many ways of doings this.
Two possible ways are by using mechanical scripting.
The first way is to use GetResultsData as shown here:
https://discuss.ansys.com/discussion/2544/how-can-i-using-scripting-get-displacements-as-function-of-time-at-certain-areas
Readapt the above to include more directions ( displacements).
Another way is via the code shown below and at the end of this post (Readapt script to include more directions ( displacements).
We can also use DPF to do this - the following code (see link below) can be easily adapted to read displacements instead of temperatures (e.g., use dpf.operators.result.displacement_Y for y-disp).
https://discuss.ansys.com/discussion/2383/print-temperatures-node-ids-and-locations-using-dpf-inside-mechanical
Script mentioned above (exports and reads data back into arrays):
analysis=ExtAPI.DataModel.Project.Model.Analyses[0] solution=analysis.Solution dirdef=solution.AddDirectionalDeformation() # add as many times as needed for x, y, z dirdef.NormalOrientation=NormalOrientationType.ZAxis solution.EvaluateAllResults() dirdef.ExportToTextFile("D:/dispz.csv") #read data in from export file above import csv nodenr=[] cx=[] cy=[] cz=[] dirdis=[] with open("D:/dispz.csv", 'rb') as f: reader = csv.reader(f) next(reader) for row in reader: print(row) nodenr.append(row[0].split('\t')[0]) cx.append(row[0].split('\t')[1]) cy.append(row[0].split('\t')[2]) cz.append(row[0].split('\t')[3]) dirdis.append(row[0].split('\t')[4])
