How to export tabular data and local maximum and local minimum values in energy probe using Python
As shown in the figure, I need to export the data from these two places. How should I implement it with Python and run it in visual studio?
Also is there a way to realize the overall export operation of the table in the Python environment?
Hi
Perhaps start and try to use this in mechanical scripting inside the automation/script console or in a python code :
mprobe=ExtAPI.DataModel.GetObjectsByType(DataModelObjectCategory.EnergyProbe)[0]
mprobe.Activate()and then see this post to get the values of the tabular data:
https://discuss.ansys.com/discussion/255/how-to-access-tabular-data-using-act
then perhaps loop/look through data to find what you want perhaps and write to a text file as needed to export.
Not sure if the above will always work if you run many simulations (say via batch)
@Erik Kostson said:
HiPerhaps start and try to use this in mechanical scripting inside the automation/script console or in a python code :
Hello, thank you very much for your answer, but when I run this code in visual studio software, it prompts "NameError: name 'MechanicalPanelEnum' is not defined". Is there any way to export this data in Python 3.9 environment?
@sunyroy You can import those global variable like this:
app.update_globals(globals(), True)
https://mechanical.docs.pyansys.com/version/stable/user_guide_embedding/globals.html#globals
