How to include custom rotation angle within pymapdl legacy function plot_principal_nodal_stress( )
Bsun12
Bsun12 Member Posts: 1
I would like to rotate the default view after plotting stress plot , by 30 Deg ,using the initial cpos returned value stored in cam_pos variable as shown below
using ansys legacy reader
rst = pymapdl_reader.read_binary(result_file)
cam_pos=rst.plot_principal_nodal_stress(
0,
"SEQV",
window_size=[500,500],
background="w",
text_color="k",
add_text=False,
show_edges=False,
#cpos='xy',
return_cpos=True,
show_scalar_bar=True,
lighting=True,
show_axes=True,
off_screen=True,
cmap='turbo',
node_components=None,
element_components=None,
is it possible to add the rotation as **kwargs ,like angle=30 or feature_angle=30 ?
other methods which can make this possible are also welcome
https://reader.docs.pyansys.com/version/stable/user_guide/loading_results.html#accessing-solution-results
Best Answers
  • James Derrick
    James Derrick Administrator, Employee Posts: 325
    admin
    Hello! Thanks for your question! I have pinged @AKD-Scripting-Team who should hopefully be able to help.
  • Rajesh Meena
    @Bsun12 Attached script helps you achieve this.
    We are getting CPOS information from current view and then rotation w.r.t view vector by required angle and get new CPOS. This would essentially change only the view up vector.
