How to copy legend settings from a Mechanical result object to a Figure using scripting?
Rohith Patchigolla
Member, Moderator, Employee Posts: 249
Currently Figures don't support native legendsettings API.
The below script (tested in 25R1) shows the automation script for the below steps. Please note that below script needs unit system in Mechanical to be in MKS (during export/import of legend) which is taken care of by the script as well.
- Export legend settings from a particular result object (say Equivalent Stress) as an xml file
- Extract GUID from the exported xml
- Import the legend as a Named legend back into Mechanical
- Apply this legend to a figure object
import os import units import re #Inputs: Name and Directory where the legend file is exported xmlFileName = "test.xml" xmlFileDir = r"D:\del5" xmlFilePath = os.path.join(xmlFileDir,xmlFileName) #Inputs: Specify from which object (Eqv Stress) to which object (Figure) legend settings are copied parentObj = DataModel.AnalysisList[0].Solution.Children[2] childObj = parentObj.Children[0] #----------------------------------------------------------------------------------- #Function to import a named legend xml file into Mechanical def import_settings(filepath): cmds = ''' var filePath = "{}"; var refLegendStyleMgr = WB.ScriptEngine.Engine.CreateActiveXObject(WB.ScriptEngine.Engine.GenWBProgId("AnsCoreObjects.AnsLegendStyleManager")); var callback = WB.ScriptEngine.Engine.CreateActiveXObject(WB.ScriptEngine.Engine.GenWBProgId("AnsCoreObjects.AnsDelegate")); callback.AddCOM(this, "OnOverwriteStyle"); refLegendStyleMgr.ImportStyles(filePath, callback,true); '''.format(filepath.replace('\\','\\\\')) ExtAPI.Application.ScriptByName("jscript").ExecuteCommand(cmds) #Function to read guid from a legend xml file def extract_guid_from_xml(file_path): # Read the XML file with open(file_path, "r") as file: xml_content = file.read() # Regular expression to match the GUID guid_pattern = r'guid="([^"]+)"' # Search for the GUID match = re.search(guid_pattern, xml_content) if match: return match.group(1) # Return the GUID else: return None # Return None if no GUID is found #----------------------------------------------------------------------------------- #Extract Current Unit system and activate mks unit system currUnitSys = ExtAPI.Application.ActiveUnitSystem ExtAPI.Application.ActiveUnitSystem = MechanicalUnitSystem.StandardMKS #Activate Parent Object and Export the Legend as an XML file parentObj.Activate() legendSettings = Ansys.Mechanical.Graphics.Tools.CurrentLegendSettings() legendSettings.ExportLegend(xmlFilePath) #Extract guid from the exported legend file guid = extract_guid_from_xml(xmlFilePath) #import the legend import_settings(xmlFilePath) cmds = ''' DS.Graphics.GfxUtility.Legend.LegendStyle="{}" '''.format(guid) #Activate the figure object needed childObj.Activate() ExtAPI.Application.ScriptByName("jscript").ExecuteCommand(cmds) Tree.Refresh() ExtAPI.Application.ActiveUnitSystem = currUnitSys
