How to automate pressure load on FSI faces in vibro-acoustics?
Erik Kostson
Member, Moderator, Employee Posts: 337
So say we have 2 named selections (NS), called fs1 and fs2. How can we loop through them and apply a pressure load and find the correct structural body only associated with that face/NS using scripting?
Best Answers
Below is one way of doing this (it uses and assumes that on the shared FSI face, we need to get the structural body and not the Fluid/Acoustic body with Water Liquid material, for the shared reference body):
model=ExtAPI.DataModel.Project.Model # refer to Model analysis = model.Analyses[0] solution = analysis.Solution impLoadGrp = ExtAPI.DataModel.GetObjectsByName('Imported Load (A2) ')[0] # change as needed geodata = ExtAPI.DataModel.GeoData ans=model.NamedSelections.Children for ns in ans: presload=impLoadGrp.AddImportedPressure() presload.Location=ns my_geob = geodata.GeoEntityById(ns.Location.Ids[0]).Bodies for myb in my_geob: my_treeb = ExtAPI.DataModel.Project.Model.Geometry.GetBody(myb) if my_treeb.Material != 'Water Liquid': presload.SharedRefBody=my_treeb
or if we have all of the FSI faces in one named selection instead (called here myfsi - change name as needed), then the below might help:
model=ExtAPI.DataModel.Project.Model # refer to Model analysis = model.Analyses[0] solution = analysis.Solution impLoadGrp = ExtAPI.DataModel.GetObjectsByName('Imported Load (A2) ')[0] # change as needed geodata = ExtAPI.DataModel.GeoData ns=ExtAPI.DataModel.GetObjectsByName('myfsi')[0] # change name of NS as needed nsids=ns.Location.Ids for nsi in nsids: presload=impLoadGrp.AddImportedPressure() selection = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.GeometryEntities) selection.Ids=[nsi] presload.Location=selection selection=ExtAPI.SelectionManager.ClearSelection() my_geob = geodata.GeoEntityById(nsi).Bodies for myb in my_geob: my_treeb = ExtAPI.DataModel.Project.Model.Geometry.GetBody(myb) if my_treeb.Material != 'Water Liquid': presload.SharedRefBody=my_treeb
