How do I check with PyDPF if a particular result is available for a time-step in my results file?
You need to scope all the time-steps in your Time scoping. DPF returns a fields container with Fields for all time-steps but where results are absent the elementary count is 0. The following code can be used as an example:
from ansys.dpf import core as dpf rst = r"\Path\to\file.rst" dpf.start_local_server(ansys_path=r"C:\Program Files\ANSYS Inc\v222") print(dpf.SERVER.info) model = dpf.Model(rst) ds = dpf.DataSources(rst) ts = dpf.Scoping() ts.ids = range(1, model.metadata.time_freq_support.n_sets + 1) stress = dpf.operators.result.stress(data_sources=ds, time_scoping=ts) stress_fc = stress.outputs.fields_container.get_data() def check_if_result_exists_at_time(fc, time_index): if fc[time_index].elementary_data_count > 0: return True return False time_index = 2 res_bol = check_if_result_exists_at_time(stress_fc, time_index) print(f"Stress result at time-step {time_index}: {res_bol}")
