Hello Experts,
I'm reaching out to seek your advice.
I occasionally encounter the following error message when launching EnSight using PyEnSight, although it doesn't happen consistently.
Error : process no longer exists (pid=42012)
Retry :
CRITICAL - - logger - handle_exception - Uncaught exception
File "D:\OV\venv_pyansys\Lib\site-packages\psutil_pswindows.py", line 673, in wrapper
return fun(self, *args, **kwargs)
File "D:\OV\venv_pyansys\Lib\site-packages\psutil_pswindows.py", line 691, in wrapper
File "D:\OV\venv_pyansys\Lib\site-packages\psutil_pswindows.py", line 775, in cmdline
return cext.proc_cmdline(self.pid, use_peb=True)
ProcessLookupError: [Errno 3] assume no such process (originated from psutil_pid_is_running -> 0)
The above exception was the direct cause of the following exception:
File "D:\OutFlowTest_250331_1942\test_2025-03-31-19-42-58\PyFluent.py", line 1603, in
).start()
File "D:\OV\venv_pyansys\Lib\site-packages\ansys\pyensight\core\locallauncher.py", line 161, in start
to_avoid = self._find_ports_used_by_other_pyensight_and_ensight()
File "D:\OV\venv_pyansys\Lib\site-packages\ansys\pyensight\core\launcher.py", line 236, in _find_ports_used_by_other_pyensight_and_ensight
process_cmdline = process.cmdline()
File "D:\OV\venv_pyansys\Lib\site-packages\psutil__init__.py", line 739, in cmdline
return self._proc.cmdline()
File "D:\OV\venv_pyansys\Lib\site-packages\psutil_pswindows.py", line 675, in wrapper
raise convert_oserror(err, pid=self.pid, name=self._name) from err
psutil.NoSuchProcess: process no longer exists (pid=42012)
I used the following code to launch EnSight:
installed_version = [item for item in os.listdir("C:\Program Files\ANSYS Inc") if item.startswith("v")]
installed_version.sort(key=lambda x: int(x[1:]))
for i in reversed(installed_version):
f="C:\Program Files\ANSYS Inc\v"+str(i)+"\CEI\bin\ensight"+str(i)+"_launcher.bat"
if(os.path.isfile(f) == True):
install = "C:\Program Files\ANSYS Inc\v"+str(i)
break
post_process = LocalLauncher(
ansys_installation=install,
batch=True,
).start()
To avoid potential conflicts with pre-installed Python modules, site-packages, etc., I've set up and used a virtual environment.
I'd greatly appreciate any insight or suggestions you might have.
Thank you!
Best regards,
Junghoon
Junghoon Lee / Senior Application Engineer, Ph.D.
State Tower Namsan 20F / 100, Toegye-ro, Jung-gu / Seoul, 04631, Republic of Korea
office: +82 2 6454 5536
junghoon.lee@ansys.com / www.ansys.com
